Topic "WinSCP copies from remote to tmp, but not to destination"
StefMSB
Problem:
Since roughly a week, I try to copy bigger project trees from a remote LINUX host to a Windows 7 System. While to transfer starts and the files get copied to the temporary Folder, the files doesn't get copied to the target Folder.
In some cases, a few files get correctly copied. After that, a bigger Transfer has the same problem.
I tried this without any effect:
- Change the temporary Directory
- Switch from INI file to Windows registry
- Toogle thos Append... Settings.
I finally upgraded to WinSCP 5.7.6. No effect either.
Effectively, I can't use WinSCP any longer.
I feel, as if WinSCP instructs Windows to copy from tmp to Destination, but that Operation somehow gets canceled.
First time problem happened
Roughly a week ago. Before that, I did use WinSCP for years without any problem.
Did updates to other System components happened?
Quite likely. Coporate Network.
Environment:
- Windows 7
- WinSCP 5.7.6
- Remote host Linux
- Protocl in user SFTP
Not sure how to debug this.
Though, why do you use the "temporary directory" mode? Can try the "shell extension" mode?
http://winscp.net/eng/docs/ui_pref_dragdrop
I would, but the respective item appeares in grey here. Can't be selected. Hm...
Did you install WinSCP? Or are you using a portable executable?
