Create 0-byte file (or template manager)
Mangamaniac
Hi!
I was wondering if you could implement a function for creating 0-byte files on both remote side and local side, with a given name and optionally more input like content from a template which is automatically placed into that generated file.
That would be extremely cool for web programmers, because we don't have to switch to damn explorer anymore :D
Waiting for feedback!
Greetings,
Mangamaniac
Re: Create 0-byte file (or template manager)
To create empty file use command File(s) > Edit new file.
There's no template function. However you can easily implement it yourself (for remote side only) by creating the template file and defining custom command like "cp /path/to/template.html !?New HTML file?!"
