Extra quotes being added to Client certificate file parameter in the GUI
Szeraax
Utah, USA
When browsing to my cert *.key, one folder has a space in it. After selecting the key, the full path is added to the GUI with a pair of quotes around it (Looks like: "C:\test folder\key.key"). When connecting to the host, I get the error:
Error
Cannot open certificate ""C:\test folder\key.key"".
System Error. Code: 2.
The system cannot find the file specified
OK Reconnect Help
Resolution is to remove the pair of quotes that are in the parameter box before saving the connection.
This is using v5.8 built 2 days ago. Please let me know if you need any additional description. Thanks for all your work!
Re: Extra quotes being added to Client certificate file parameter in the GUI
Thanks for your report. I have fixed this. I'm sending you a development build.
Szeraax
Utah, USA
I have confirmed that it is fixed. Thanks.
