Topic "Copy - does WinSCP inform us of replacing files?"
dsc
When I drag and drop a file from the remote side that is already on the local side, I do not get warnings that I am overwriting the file.
Should I get these? If so how do I check to make sure they are set. I am using Win XP pro.
Dave
Dave
You should not. Also you cannot, or at least I don't know how to do that. I'm sorry. This is true only for drag&drop, otherwise you're warned.
