Win SCP crash report
maltham
Windows 10 64bit
WinSCP 5.7.6
One SFTP session open to a remote server and working OK.
Tried to open a new session to a local network server that is normally connected by wifi BUT the wifi link had been down. I reset the wifi dongle and the server connected to my router using it's normal IP address. The router shows the server connected at the correct name & address.
Tried to connect with WinSCP several times - WinSCP could not find the server (using server name not IP address). After several attempt to reconnect got the error "Invalid Access to Memory" and the first trace below.
Tried to connect a new session to a remote server (same server as already connected to) to test WinSCP was working and got the same error, but with the second trsace below. This time I couldn't kill the error window and had to kill WinSCP using task manager.
After WinSCP restart the program worked OK.
Note: the PC had been left idle for several hours and had been in sleep mode immediately prior to all this. I don't think this is a serious fault.
First trace:
(00710B01) TTerminal::GetUserNameW
(0008A52F) ntdll.dll
(00077DAA) ntdll.dll.KiUserExceptionDispatcher
(0067C1CA) TRemoteFile::GetIsInaccesibleDirectory
(00617E1C) TCustomUnixDriveView::UpdatePath
(006182C1) TCustomUnixDriveView::LoadPathEasy
(00617ECF) TCustomUnixDriveView::UpdatePath
(006184B7) TCustomUnixDriveView::LoadPath
(00618430) TCustomUnixDriveView::LoadPath
(00618560) TCustomUnixDriveView::LoadDirectory
(00614AD9) TUnixDirView::DoReadDirectoryImpl
(000055A8) TCustomScpExplorerForm::SetTerminal
(00079289) TTerminalManager::TerminalReady
(00076742) TTerminalManager::SetActiveTerminal
(00075CEF) TTerminalManager::FreeActiveTerminal
(00076114) TTerminalManager::ConnectActiveTerminal
(000769F4) TTerminalManager::DoSetActiveTerminal
(000150CC) TCustomScpExplorerForm::NewSession
(00019E50) TCustomScpExplorerForm::SessionsPageControlChange
(0021C315) Vcl::Controls::TWinControl::WndProc
(0021740C) Vcl::Controls::TControl::Perform
(0021C47B) Vcl::Controls::_17076
(001D70B8) Vcl::Forms::TCustomForm::WndProc
(0078D54D) Vclcommon::C2516_0
(0021B95C) Vcl::Controls::TWinControl::MainWndProc
(003402A8) System::Classes::_18201
(000374F1) USER32.dll
(00015C3B) USER32.dll
(0001581B) USER32.dll
(0001C167) USER32.dll
(00077D84) ntdll.dll.KiUserCallbackDispatcher
(00014EDE) USER32.dll.SendMessageW
(0007DBD8) COMCTL32.DLL
(00073D8F) COMCTL32.DLL
(0002106D) COMCTL32.DLL
(00071457) COMCTL32.DLL
(0002174B) COMCTL32.DLL
(000159D2) USER32.dll.CallWindowProcW
(0021C426) Vcl::Controls::TWinControl::DefaultHandler
(003FEE7F) Dragdrop::TDragDrop::WndMethod
(0001553C) USER32.dll
(000152FB) USER32.dll.DispatchMessageW
Second Trace:
Invalid access to memory.
(0070F590) TTerminal::GetIsCapable
(003823D8) System::Actions::TContainedActionList::UpdateAction
(00169ECE) Vcl::Actnlist::TCustomAction::Update
(001DBD36) Vcl::Forms::_16777
(001DBDB4) Vcl::Forms::TCustomForm::UpdateActions
Re: Win SCP crash report
