Topic ".Net Assembly - Error: Exception: WinSCP.SessionLocalException: Element "cwd" not found in the log f"
tgurinder
This is the code I am using. I am able to connect via WinScp GUI using same credentials. I tried by removing/setting log file paths..same error in both cases. Can anyone help me to resolve it.
With sessionOptions
.Protocol = Protocol.Sftp
.HostName = glo.strBBSFTPServerName
.PortNumber = glo.Port
.UserName = glo.SFTPUsername
.Password = glo.SFTPPassword
.SshHostKeyFingerprint = glo.sshKey
End With
With session
.DisableVersionCheck = True
.DebugLogPath = "C:\Development\WinSCPDebugLog.txt"
.SessionLogPath = "C:\Development\WinSCPSessionLog.xml"
'''.XmlLogPath = "C:\Development\Products\MB\MBLogs\MBDataFeedAgent\WinSCPXMLLog.xml"
End With
session.Open(sessionOptions)
Log file says:
SessionLogReader.Read leaving
[2016-02-10 15:47:23.755Z] [0003] ExeSessionProcess.ProcessEvent leaving
[2016-02-10 15:47:23.755Z] [0001] SessionLogReader.Read entering
[2016-02-10 15:47:23.755Z] [0001] Read node 10: Whitespace
[2016-02-10 15:47:23.755Z] [0003] ExeSessionProcess.ProcessEvent entering
[2016-02-10 15:47:23.755Z] [0001] Log contents has not changed
[2016-02-10 15:47:23.755Z] [0001] SessionLogReader.Read leaving
[2016-02-10 15:47:23.755Z] [0001] Read node 11: EndElement group
[2016-02-10 15:47:23.755Z] [0003] ExeSessionProcess.ProcessInputEvent entering
[2016-02-10 15:47:23.755Z] [0001] Exception: WinSCP.SessionLocalException: Element "cwd" not found in the log file
[2016-02-10 15:47:23.755Z] [0001] ElementLogReader.Dispose entering
[2016-02-10 15:47:23.755Z] [0001] ElementLogReader.ReadToEnd entering
[2016-02-10 15:47:23.755Z] [0001] ElementLogReader.ReadToEnd leaving
[2016-02-10 15:47:23.755Z] [0001] ElementLogReader.Dispose leaving
at WinSCP.CustomLogReader.WaitForNonEmptyElement(String localName, LogReadFlags flags)
at WinSCP.Session.Open(SessionOptions sessionOptions)
[2016-02-10 15:47:23.755Z] [0001] Session.Cleanup entering
[2016-02-10 15:47:23.755Z] [0001] Terminating process
[2016-02-10 15:47:23.755Z] [0001] Command: [exit]
[2016-02-10 15:47:23.755Z] [0001] ExeSessionProcess.ExecuteCommand entering
[2016-02-10 15:47:23.755Z] [0001] ExeSessionProcess.ExecuteCommand leaving
[2016-02-10 15:47:23.755Z] [0003] Scheduling output: [winscp> exit]
[2016-02-10 15:47:23.755Z] [0003] ExeSessionProcess.ProcessInputEvent leaving
[2016-02-10 15:47:23.755Z] [0001] ExeSessionProcess.Close entering
[2016-02-10 15:47:23.755Z] [0001] Waiting for process to exit (2000 ms)
[2016-02-10 15:47:23.864Z] [0003] Process 6388 exited with exit code 0
tgurinder
Hi All,
This error was due to mismatch in .EXE installed on my server and .Net wrapper referenced in code. Provided Executable path (as Version can changes on server) and now able to connect.
session.ExecutablePath
Thought of sharing it as I have spent lot of time on it.
