Script vs winscp.exe
Danny55
When I use winscp.exe using FTP, port 990 I can log in with no issues.
When I use the same settings from a script, I get "Waiting for welcome message..."
"Connection Failed"
"Timeout detected"
Any ideas??
Re: Script vs winscp.exe
Please attach a full log file both from GUI and script showing the problem (using the latest version of WinSCP).
