SQL SSIS 2014 - bad service request ssh-connection
Covi
Colorado - Pikes Peak
2016-02-24 17:49:31.847 WinSCP Version 5.7.6 (Build 5874) (OS 6.1.7601 Service Pack 1 - Windows Server 2008 R2 Enterprise)
I seem to get a connection then failure, can someone offer direction
Error: Error when using WinSCP to upload files: WinSCP.SessionRemoteException: Server sent disconnect message
type 2 (protocol error):
"bad service request ssh-connection" ---> WinSCP.SessionRemoteException: Authentication failed.
--- End of inner exception stack trace ---
Thanks for the assistance.
  • winscp.log (39.08 KB, Private file)
Re: SQL SSIS 2014 - bad service request ssh-connection
It looks like the SSH is blocked on your server.
Are you able to connect with any other SSH/SFTP client?
Covi
With WinSCP I can connect to the End Point and perform file operations. See the attached image.
Thanks for your assistance - Covi
  • winSCPConnection.PNG (36.64 KB, Private file)
Description: Image of WinSCP properties prior
