Topic "Host Does Not Exist"
crystina
I just registered a new domain name. When I try to log in via WinSCP, I get the error above. Can you tell me why or what may cause it? And, if you want to be really helpful, maybe tell me how to fix it? Laughing
You domain is probably not known by your DNS server. You should wait several hours or use IP address instead of the domain name.
Crystina
Thanks so much for responding so quickly. I am now getting a different error, one that I also have not seen before. (ESshFatal) Authentication failed.
What is this?
Crystina
Here's my log file...
. WinSCP Version 3.7.1 (Build 257) (OS 5.1.2600 Service Pack 1)
. Login time: Friday, July 22, 2005 10:51:51 PM
. Session name: newjac@sftp.newjac.org
. Host name: sftp.newjac.org (Port: 22)
. User name: newjac.org (Password: Yes, Key file: No)
. Transfer Protocol: SFTP (SCP)
. Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. SSH Bugs: -,-,-,-,-,-,-,-,
. Proxy: none
. Shell: default, EOL: 0
. Cache directory changes: Yes, Permanent: Yes
. Looking up host "sftp.newjac.org"
. Connecting to 66.15.12.224 port 22
. Server version: SSH-2.0-2.4.0 SSH Secure Shell (non-commercial)
. We claim version: SSH-2.0-WinSCP-release-3.7.1
. Host key fingerprint is:
. ssh-dss 1024 08:4d:28:1d:6a:0f:f3:f0:5e:f0:fa:c0:95:46:0d:c3
. Initialised Blowfish client->server encryption
. Initialised Blowfish server->client encryption
. Initialised HMAC-SHA1 client->server MAC algorithm
. Initialised HMAC-SHA1 server->client MAC algorithm
! Using username "newjac.org".
. Session password prompt (newjac.org@sftp.newjac.org's password: )
. Using stored password.
. Sent password
* (ESshFatal) Authentication failed.
* Authentication log (see session log for details):
* Using username "newjac.org".
* Connection has been unexpectedly closed. Server sent command exit status 0.
You server closes connection once it gets your password. You need to ask your server administrator.
