Want to automate download of files from Sftp to local directory using batch file
anika
hi all,
i want to download files from sftp folder using batch file to any of my local folder .
Could any one give a detailed description on how to do the same ?
thanks in advance.
Anika
I cannot find the console window in winscp where I have to write Commands for automation .Can you guide those steps to me as I am new to this .
I tried to find that window from Commands -> Open Terminal in Winscp but got this error :
Error skipping startup message. Your shell is probably incompatible with the application (BASH is recommended).
Thanks in advance .
MM
VBA to download a file from WinSCP if the absolute path of remote server is not available
Hi , I am kind of a beginner in VBA. I want to download a file from remote server to local. Certain files get stored in subdirectories of a root folder and the subfolder names can be dynamic. I have the file name with me. I need to download the file from winscp to location without giving exact path
path : /u/test/
filename: a.txt
if this file is stored in /u/test/*/ (any subfolder , how can write the shell command)
errorCode = wsh.Run("C:\winscp577\WinSCP.com /command ""open user:pwd@domain"" ""lcd " & tempLocation & """ ""get /u/test/*/a.txt""" ""exit""", windowStyle, waitOnReturn)
The above code does not seem to work
Re: VBA to download a file from WinSCP if the absolute path of remote server is not available
path : /u/test/
filename: a.txt
So do you want to download all files stored anywhere in a remote directory tree to the same local folder?
See https://winscp.net/forum/viewtopic.php?t=23759
Though you cannot use Session.EnumerateRemoteFiles in VBA. So you have to recursively use Session.ListDirectory.
