Topic "Trouble with filemask when running a synchronise"
shiny76
Can anyone help me. I have to retrieve files from a source directory on a source server and put them on a different server in a different directory. I only want to transfer new or amended files and only files that follow a particular naming convention.
Here is my script:
# Connect to source server
open sftp://<sourceUsername>:<sourcePassword>@source.myDomain.com<sourceDirectory>
# Download all files that haven't been downloaded previously
lcd C:\SFTP_temp\
synchronize -filemask="ABC*.csv" local
# Close connection to source server
close
# Connect to destination server
open ftp://<destinationUser>:<destinationPwd>@destination.myDomain.com:21<destinationDir>
# Upload all files that haven't been uploaded previously
lcd d:\SFTP_temp\
synchronize -filemask="ABC*.csv" remote
# Close connection
close
# Exit WinSCP
It does appear to transfer all files with the naming convention ABC*.csv, BUT it also appears to transfer any other file as well.
Am I doing something wrong? Any pointers?
Thank you!
Name a file that was transferred but should not have been.
