Topic "synchronize remote problem"
seven.7
I have a serious problem with the sync command.
I have to synchronize several image files (about 20,000) from a Windows folder (the remote server is linux). The problem is that some files are synchronized although actually exist on the remote server. This means that synchronizes always in vain the same files. I did not understand the question timestamps ... help ...
Please attach a full log file showing the problem (using the latest version of WinSCP). Name a single file that was synchronized, while it should not have been.
seven.7
I have send. Thanks
seven.7 wrote:
How it was generated the log?
I run the script and is the synchronization was performed.
I stopped the script and I did it again. It has synchronized the same file again.
an file for example: “DS7101250.jpg”
Thank you very mutch
In the first run, WinSCP uploaded the DS7101250.jpg file.
In the second run, when WinSCP lists the remote directory to find differences, the DS7101250.jpg file is not there. So it uploads it again.
It does not look like a problem with WinSCP.
