Topic "Script: Unknown command '2048'."
akksam
Hi, Could anyone please help in come out of this challenge? Your earliest advise will be greatly appreciated.
When I trigger the following command from PowerShell code getting "Script: Unknown command '2048'. " but if I execute the same from DOS it works fine.
I am not able to understand why this command is not working in PowerShell.
The execution command coded in powershell is that G:\winscp577\winscp /command "open sftp://name:password@domain.com -hostkey=""ssh-rsa **** **:**:**:**:**:**:**:**:**:**:**:**:**:**:**:**""" "ls" /log="G:\winscp577\winscp.log" /loglevel=0
winscp.log says;
< 2016-05-01 11:23:18.795 Script: Active session: [1] name@domain.com
> 2016-05-01 11:23:18.795 Script: 2048
< 2016-05-01 11:23:18.795 Script: Unknown command '2048'.
. 2016-05-01 11:23:18.795 Script: Failed
. 2016-05-01 11:23:18.795 Script: Exit code: 1
. 2016-05-01 11:23:18.795 Closing connection.
. 2016-05-01 11:23:18.795 Sending special code: 12
. 2016-05-01 11:23:18.795 Sent EOF message
It's looks like a PowerShell issue, not WinSCP one.
The PowerShell messes with the quotes on WinSCP command-line somehow.
But I'm no PowerShell expert to tell you how to escape them.
Why don't you use WinSCP .NET assembly?
https://winscp.net/eng/docs/library_powershell
akksam
Thanks ! the requirement is to use PowerShell code and not any dll's. would you please hint anything to resolve this from powershell?
akksam
Found the root cause of the issue but not sure what would be the fix. Kindly advice
Log when I manually executed the command from DOS this works fine
. 2016-05-10 01:01:23.905 Switch: /command
. 2016-05-10 01:01:23.905 Parameter: open sftp://name:password@domain.com -hostkey="ssh-rsa 2048 **:**:**:**:**:**:**:**:**:**:**:**:**:**:**:**"
. 2016-05-10 01:01:23.905 Switch: /log=G:\winscp577\winscp.log
. 2016-05-10 01:01:23.905 Switch: /loglevel=1
Log when I executed the command from PowerShell this is not working
Powershell code: G:\winscp577\winscp /command "open sftp://name:password@domain.com -hostkey=""ssh-rsa **** **:**:**:**:**:**:**:**:**:**:**:**:**:**:**:**""" /log="G:\winscp577\winscp.log" /loglevel=0
Not sure why the command is separated in to 3 lines and there is no double quotes before ssh-rsa
. 2016-05-10 01:13:33.609 Switch: /command
. 2016-05-10 01:13:33.609 Parameter: open sftp://name:password@domain.com -hostkey=ssh-rsa
. 2016-05-10 01:13:33.609 Parameter: 2048
. 2016-05-10 01:13:33.609 Parameter: **:**:**:**:**:**:**:**:**:**:**:**:**:**:**:**"
. 2016-05-10 01:13:33.609 Switch: /log=G:\winscp577\winscp.log
. 2016-05-10 01:13:33.609 Switch: /loglevel=1
That's what I've meant.
But again, I'm not a PowerShell expert. Ask in some PowerShell community, or maybe at stackoverflow.com or superuser.com.
