The server response "Permission denied", how to fix it?
Diandian
I use these code to upload the file:
   Protocol = Protocol.Sftp,
   HostName = "devserver",
   UserName = "ftpClient",
   Password = "123456",
   SshHostKeyFingerprint = "ssh-rsa 1024 63:3d:d2:6e:19:f5:2b:e4:be:02:3b:5b:ab:d3:75:9a"
   session.DisableVersionCheck = true;
   session.SessionLogPath = @"d:\winscpLog.txt";
   session.Open(sessionOptions);
   TransferOptions transferOptions = new TransferOptions();
   transferOptions.TransferMode = TransferMode.Binary;
   TransferOperationResult transferResult;
   transferResult = session.PutFiles(@"D:\Cache\DCCV2\*", "/home/ftpClient/", false, transferOptions);
   transferResult.Check();
   foreach (TransferEventArgs transfer in transferResult.Transfers)
      Console.WriteLine("Upload of {0} succeeded", transfer.FileName);
But response error: can not create folder '/home/ftpClinet/xxx/', error code:3, Permission denied.
The server SSHd set SFTP home path is "E:\FTP".
My question is:
How to write the remotePath?
How to fix this permission denied?
Thanks.
Re: The server response "Permission denied", how to fix it?
Are you able to upload the files to that folder using any (even GUI) SFTP client?
Hello
I am getting Permission Denied error, but when I upload same file to same directory on SFTP using Internet explorer, then it works successfully.
Is there any setting i am missing?
Internet Explorer does not support SFTP. It supports FTPS (FTP over TLS/SSL). What is a completely different protocol.
You are possible using a different protocol in WinSCP than in IE.
