Topic "Unable to authenticate SFTP Credentials using Batch Script"
sundar2013
WINSCP - Version 5.12
Version of Windows - Windows 7
Transfer Protocol - SFTP
Error : Disconnected: Unable to authenticate
I am connecting SFTP Server using username and password directly in the batch script, but it is not working. I am not using host key and I am using the password directly.
I able to connect to my SFTP server using Graphical user interface with same credentials.
The Batch Script is mentioned below.
option batch abort
open sftp://username:password@Server Name
Password had characters like +-. I don't know this will cause the issue.
Error :
. 2016-05-13 14:39:02.283 Using stored password.
! 2016-05-13 14:39:02.315 Further authentication required
. 2016-05-13 14:39:02.316 Further authentication required
. 2016-05-13 14:39:02.318 Attempting keyboard-interactive authentication
. 2016-05-13 14:39:02.347 Prompt (6, SSH server authentication, Using keyboard-interactive authentication., Enter password: )
. 2016-05-13 14:39:02.349 Disconnected: Unable to authenticate
Please help me to resolve it.
Thanks.
Sundaramurthy J.
winscp.log (4.65 KB) [Download]
Description: (none)
Please attach a log file from GUI for comparison.
You also better use the latest version of WinSCP.
sundar2013
Herewith I am attaching the log file from GUI WINSCP.
From GUI if I enter the password directly it is asking for the password again & again during authentication. If I check the option to save the password then it won't ask and started working in GUI.
I am doubting that through script password is not storing correctly.
Please help me.
Regards,
Sundaramurthy J.
Winscp _GUI.log (6.77 KB) Private file
Description: GUI Log File for Comparision
sundar2013
I have resolved the issue. Password has special characters that caused the problem. I have converted special characters to Hexa that solved the problem.
Thanks for your help.
Regards,
Sundaramurthy J.
Thanks for your feedback.
