Topic "Version mis-match"
Bill Long
Getting the following message and would like to know if doing this
has any strong implications as I have quite a few programs previously built that are using this version w/no issues. This being a new program test. Using VB 2008 and calling WinSCP which is
not unusual for me.
And if ok, where do I put this code?
Logged message:
The version of C:\Program Files (x86)\WinSCP\WinSCP.exe ( does not match version of this assembly \\\dfs\users\BLong\My Documents\Visual Studio 2008\Projects\STRATA\STRATA\bin\Debug\WinSCP.dll ( You can disable this check using Session.DisableVersionCheck (not recommended).
You should have a compatible (5.1.7) copy of the winscp.exe along with the winscp.dll with all your programs. You should not rely on the installed version of WinSCP.
