Topic "Polish charset"
1) WinSCP is cool Smile
2) I use Polish windows2000, I can't enter proper polish names for the files. Winscp names files/dir with polish letters but putty and "ls /dir/" shows that polish letters are lost!
Where can I change that option, if there is one...?
I belive winscp should use iso8859-2, When I create directory using putty (mkdir /ąęśłńżź - polish letters Smile ) win scp does not display proper letters, it looks like it displays raw ISO8859-2 (not interpreted, they look like html polish letters in html code /web page source/ )
thank you
SFTP allows unicode encoding only. If you SFTP server does support that, WinSCP cannot do anything about it. Read more in FAQ.
