Topic "Commands before script?"
Nozavi
Quote:
If both /script and /command parameters are used, commands from script file are executed first.
Would it be possible to create a switch that makes winscp run the commands first and then the script?
I have a very long list of commands that I want to execute in just one go, so only using commands is out of the question and storing the user/password in plaintext in the script is again out of the question... the perfect solution would be to first login through the commands and then go through the long list of commands in the script...
Would that be possible? I'd really appreciate it
Thank you Exclamation
You can do it like:
winscp.net sftp://username:password@example.com/ /script=script.txt
Or even better, use environment variables in the script:
open sftp://%USER%:%PASS%@example.com/
See also https://winscp.net/eng/docs/guide_protecting_credentials_for_automation
