Compatible with Windows 10
pbally
If I were to upgrade my PC to Windows 10 would my version of WinSCP (5.5.5) be compatible? If not, which versions are compatible?
Re: Compatible with Windows 10
5.5.5 should be compatible. But you should always use the latest version. The latest version is definitely compatible with Windows 10.
