VBA script to download files from excel only downloads each file once.
PanV
Hi all.
I am using WinSCP's vba example to download files via excel macros. (eventually I want these files opened, based on chosen date inputs, as individual worksheets in the workbook with the macro to download the files, so I can create reports)
I have successfully gotten the code to download files from the SFTP server into a local directory of my choosing, opting to NOT delete the files from teh server once downloaded.
However, once a file has been downloaded, if I delete the files from the local directory and run the macro again, it does not download the same files again. If I try another directory that I have not touched yet, it downloads the files just fine. But again, I can only download each file once to a local directory via this code.
How can I ensure that the same files are downloaded each time when prompted?
Many thanks
Re: VBA script to download files from excel only downloads each file once.
That does not make sense.
Andrew89
It have many sense because I have to do this in my work, I have to copy 20 excel books to a local file and after execute the macros to filter all this data books to a new book.
