Topic "Delay when opening WinSCP for the first time (since updating to 5.9.1)"
SteveGER
I just updated WinSCP from 5.7.7 to 5.9.1 and I have a problem which hasn't been there before:
When I open Winscp for the first time after rebooting (Windows 7 x64), the first thing I see is the blank main windows and it takes at least (!) 10-20 seconds for the connections-box to show up.
Then everythings works smooth.
When I close and reopen WinSCP this does not happen again, the connectios-box shows up immediately, just like before the update to 5.9.1..
I have my connections saved to a winscp.ini in my Users path and start Winscp using a shortcut: "C:\Program Files (x86)\WinSCP\WinSCP.exe" /ini=C:\Users\.......\WinSCP.ini
I already tried starting without ini, using a defauls shortcut or starting the exe from the program files folder - same error again..
Can anyone "confirm" this?
SteveGER
I already tried steps to troubleshoot, which were mentioned in other topics here:
- Try to restart the machine
- Try to run WinSCP with blank configuration (winscp.exe /ini=nul)
=> Both do not solve the problem.
In fact everytime I restart my PC the delay happens again, launching WinSCP for the first time (even with ini=nul!).. Second launch works fine/immediately.
SteveGER
Hello Martin,
thanks for your reply, I just sent you the email as requested.
Looking forward for your reply. Wink
https://winscp.net/tracker/show_bug.cgi?id=1460
