Command line or Batch file Script for new files in last day
randydover
TN
I have configured the console to connect to a site and it will transfer files.
I need to automate this so it can be done via a scheduled task in Windows.
The command I am using successfully connects to the remote server, and attempts to download, but the log shows "Missing parameter for command 'get'."
What I am attempting to do is get files changed / created in the last day and download them to a folder on C:
The commands I'm using are:
open sftp://remotesite -hostkey="ssh..."
get -filemask="/Users/RFTP772/*>=1D"
I have also tried:
get -filemask=/Users/RFTP772/"*>=1D", "C:\upload\extracts"
and:
get -filemask=/Users/RFTP772/"*>=1D C:\upload\extracts"
Every time I issue any of those commands I get in the log file:
I have looked a lot in the forums, but do not know how to get past this. I am very familiar with scripting, but not with WinSCP. As I am not familiar with WinSCP script, could someone give me the exact command to get all files changed in the last day and put them in C:\upload\extract
I have tried saving the options from the console session, but it doesn't have the get commands, so I don't know how to pull down the files and put them in the folder I need them to go into. The console "generate" does not have the commands to get and save the files, though that is in the console. Is there a way to get the "generate" to show the commands needed?
I did notice there are significant differences between the "script" and "batch" commands when I generate the script. I am creating a batch file to pull the files, and will use a scheduled task to call that batch file.
Thanks to all.
Re: Command line or Batch file Script for new files in last day
You want this:
get /Users/RFTP772/*>=1D
If you need to download even files in subfolders, then you need the -filemask:
get /Users/RFTP772/* -filemask=*>=1D
Martin,
Thanks! That did it.
I did find I had to put the "\" at the end of extracts, that was the only thing I had to change, other than your change.
