Topic "Failed file transfer resumes"
When a transfer is interrupted, resumption fails when the file is large and more than 2gb have already been transferred. I assume this is a winscp bug - has anyone run across this?
I works for me. What server do you use? Can you post an error message?
I used the titan FTP server and in fact it seems to break without retrying at the 2gb mark. I am trying again with a cygwin sftp server. The error was cryptic - error 4 and 6, but I did not save the exact text. Will rerun tests and get specifics. Thanks!
I am using titan because regular linux sftp has poor logging. Oh, sure, you can patch it, but it's still pretty abysmal. Titan has a nice set of options but I am flexible. If anyone out there has recommendations for a nice GUI that combines throttling, ip address restrictions, auto home dir creation, disk quotas, etc. please let me know!
Tried again against a cygwin sshd/sftp server, and sure enough, it broke at 2gb, and I'd guess it's winscp that's the problem. When I reconnected to try and resume, I saw a negative file size in the winscp window, so perhaps you have some 32bit signed int goodness around. So 2 sftp servers up, 2 failures. I am using a cygwin sftp client now to replicate.
FWIW, the error message I got was
Bad message (badly formatted packet or protocol incompatibility).
Error code: 5
Error message from server: Bad message
Request code: 6
From cygwin's sftp server.
I'll test it with cygwin. With Vandyke VShell it works.
Thanks for the quick response. FYI, kudos on WinSCP - it's a great client and very useful for a number of projects I have. Thanks!
Although I do have a question for you - why Borland? ( I poked around the source yesterday. )
I ran some more tests ( testing large file transfers takes some time! )
cygwin sftp client -> cygwin sftp server fails
winscp -> cygwin server fails
winscp -> Titan fails
Both file systems are ntfs. Titan is commercially supported and they claim that large files should not encounter problems, which is what makes me think it's probably WinSCP - although nothing is certain. Titan has a free download eval, or I can set up a server for you if you'd like to test.
I can get by by just splitting files pre-transfer to less than 2gb but am stubborn enough to want to find a solution. Thanks again for your help.
Why not? Smile I was the only RAD environment I had experience with at the time I've started with WinSCP project (5 years ago).
I have tried it on cygwin (OpenSSH for Windows) and it works. So it seems that it is rather server-releated (HDD filesystem or something).
> So it seems that it is rather server-releated (HDD filesystem or something).[/quote]
Odd. I have NTFS on both machines, and also many large files ( >2gb ) on both. Breaking at 2gb seems an odd coincidence. I am using sftp, not scp, if that helps.
I also find connections breaking during transfers when trying over the net rather than just over my local network. Will adjusting the timeout parameter help with this? If a connection is severed, is there an auto-reconnect option?
That depends on reason why the connection breaks. Just try, you'll see Smile
No.
