same archive but with diferent size
leonardo07746
cuba
Hi, my script works just fine and it has no problem when mirrowing two files, but when some content has been added to the source file and therefore its size increased, the destiny file keeps its former size and it won't increase like the source, this is my script
@echo off
winSCP.com /command ^
   "option batch abort" ^
   "open ftp://ftpmetgooptildno:ftpfgop@192.168.xxx.21/" ^
   "synchronize local C:\Sabic\JOURNAL /Journals/TRASVAL -filemask=*>"2016-09-20 "
   "close" ^
   "quit" ^
   /log="C:\LOGS_JOURNALS\logsdelScript_!Y_!M_!D_!T.log" /loglevel=1
 "quit"
Many thanks
Reply with quote E-mail
Re: same archive but with diferent size
