Topic "Command line synchronization - logging output"
I am running on the command line to manually synchronize a directory over SFTP. This works great.
What I want to do however, is schedule a job to run this at regular intervals and log the output to a text file.
I created a batch file to do this that contains: /console /script=sync.txt >> sync.log
Problem is that because of the way's synchronize outputs its file transfers, updating its progress with control characters, only one of the files transferred is ever written to the sync.log.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] user@host
C:\Documents and Settings\localdir
Local 'dir' => Remote 'dir'
...\Test\test1.txt | 0 kB | 0.0 kB/s | ascii | 100%
Does anyone know of a way to record all of the output?
I'll try to fix this in the next version.
