Disabling commands history in winscp.com
Alopumo
Where does WinSCP keeps the history of typed commands?
I am using /ini=nul and /nointeractiveinput but winscp.com keeps an history of the typed commands.
However, if I close the command prompt (cmd.exe) and restart winscp, the history is empty (which is fine by me).
I just want to be sure that WinSCP does not keeps any history.
Thank you in advance.
Re: Disabling commands history in winscp.com
WinSCP does not keep history of its commands executed in scripting mode.
It's a feature of Windows console window, that you can scroll back to previous commands. Afaik, Windows does not save the history anywhere either.
