Executing remote php file gives "No such file or directory" error
johnywhy
Bay Area
Executing mediawiki rebuildall.php
See screenshot attached
Gives error:
Command '"./rebuildall.php"'
failed with return code 2 and error message
./rebuildall.php: line 1: ?php: No such file or directory
./rebuildall.php: line 2: /CmdTool.log: Permission denied
./rebuildall.php: line 3: 7zip.inc: command not found
./rebuildall.php: line 4: 7zip.inc: command not found
./rebuildall.php: line 5: 7zip.inc: command not found
./rebuildall.php: line 6: 7zip.inc: command not found
./rebuildall.php: line 6: you: command not found
./rebuildall.php: line 7: 7zip.inc: command not found
./rebuildall.php: line 8: 7zip.inc: command not found
./rebuildall.php: line 8: either: command not found
./rebuildall.php: line 9: syntax error near unexpected token `at'
./rebuildall.php: line 9: ` * (at your option) any later version.'.
Re: Executing remote php file gives "No such file or directory" error
If you want to execute a script file directly, it has to have "Shebang" line:
https://en.wikipedia.org/wiki/Shebang_(Unix)
As your file script does not have one, you have to execute it by explicitly running a script interpreter.
You should really read MediWiki documentation:
https://www.mediawiki.org/wiki/Manual:Rebuildall.php#Usage
cd /path/to/wiki/maintenance
/path/to/php rebuildall.php
