Run winscp from IIS7.5 vbscript Active Server Pages
Michael_P
I installed winscp as Administrator and registered it with sucessfully with
c:\Windows\Microsoft.NET\Framework64\v4.0.30319\RegAsm.exe "c:\Program Files (x86)\WinSCP\WinSCPnet.dll" /codebase /tlb:WinSCPnet64.tlb
My code produces the following error:
WinSCPnet Fehler "80131500'
"WinSCP process terminated with exit code 0. There was no output. Response log file C:\Windows\TEMP\wscp0334.033C0D9D.tmp was not created. This could indicate lack of write permissions to the log folder or problems starting WinSCP itself." on session.open
Code
Dim sessionOptions
Set sessionOptions = Server.CreateObject("WinSCP.SessionOptions")
With sessionOptions
.Protocol = Protocol_Sftp
.HostName = myHostname
.UserName = mysername
.Password = myPassword
.GiveUpSecurityAndAcceptAnySshHostKey = true
End With
Dim session
Set session = Server.CreateObject("WinSCP.Session")
session.Open sessionOptions
If I set the directory:
session.DebugLogPath = myfileDirectory
session.SessionLogPath = myfileDirectory
mscorlib Fehler "80070005'
Der Zugriff auf den Pfad "D:\.." wurde verweigert.
Any Ideas?
Michael
Re: Run winscp from IIS7.5 vbscript Active Server Pages
You may need to use Use the Session.ExecutableProcessUserName and the Session.ExecutableProcessPassword to configure the local account to use for the WinSCP process.
Though in general, WinSCP .NET assembly is not the right tool to be used for web development.
https://winscp.net/eng/docs/library#purpose
