problem getting file
harry
I have a problem getting a file from the server.
(It's always the same behaviour)
When I try to get the file by using the exact name of the file it doesn't work (look below), if I use an "*" in the filename then it works.
How can that be ?
(with the "*" i get more files that I want)
Harry
open scp://extcel17:pwd@dsdm
get qisexcelsheet.cs*
close
Session started.
Active session: [1] extcel17@dsdm
qisexcelsheet.csv | 2 kB | 8,4 kB/s | ascii | 100%
Session 'extcel17@dsdm' closed.
get qisexcelsheet.csv
close
Session started.
Host has not answered for 15 seconds.
Wait for another 15 seconds? Pressing 'Abort' button will close session.
(A)bort, (R)etry: Abort
Copying files from remote side failed.
Terminated by user.
harry
more information
i work with version 3.7.6 (Build 306) of WINSCP
and putting the file to remote works fine.
the error appears only by getting the file FROM remote
Re: more information
Can you turn on Debug2-level logging to file and try again? Then do the same via GUI and post both logs or send them to me.
