Topic "'groups' command issue"
mulanee
When I connect on my router , I get a message of error 127 due to a bad groups command.
This is my log:
Quote:
. 2006-01-02 22:21:06.000 --------------------------------------------------------------------------
. 2006-01-02 22:21:06.000 WinSCP Version 3.8.0 (Build 312) (OS 5.0.2195 Service Pack 4)
. 2006-01-02 22:21:06.000 Login time: lundi 2 janvier 2006 22:21:06
. 2006-01-02 22:21:06.000 Session name: root@serveur
. 2006-01-02 22:21:06.000 Host name: 10.0.0.1 (Port: 22)
. 2006-01-02 22:21:06.000 User name: root (Password: Yes, Key file: No)
. 2006-01-02 22:21:06.000 Transfer Protocol: SCP
. 2006-01-02 22:21:06.000 SSH protocol version: 2; Compression: No
. 2006-01-02 22:21:06.000 Agent forwarding: Yes; TIS/CryptoCard: Yes; KI: Yes; GSSAPI: No
. 2006-01-02 22:21:06.000 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2006-01-02 22:21:06.000 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2006-01-02 22:21:06.000 SSH Bugs: -,-,-,-,-,-,-,-
. 2006-01-02 22:21:06.000 SFTP Bugs: -,-,-
. 2006-01-02 22:21:06.000 Proxy: none
. 2006-01-02 22:21:06.000 Return code variable: Autodetect; Lookup user groups: Yes
. 2006-01-02 22:21:06.000 Shell: default, EOL: 0
. 2006-01-02 22:21:06.000 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2006-01-02 22:21:06.000 Cache directory changes: Yes, Permanent: Yes
. 2006-01-02 22:21:06.000 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2006-01-02 22:21:06.000 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2006-01-02 22:21:06.000 Looking up host "10.0.0.1"
. 2006-01-02 22:21:06.000 Connecting to 10.0.0.1 port 22
. 2006-01-02 22:21:06.031 Server version: SSH-2.0-dropbear_0.44test4
. 2006-01-02 22:21:06.031 We claim version: SSH-2.0-WinSCP_release_3.8
. 2006-01-02 22:21:06.031 Using SSH protocol version 2
. 2006-01-02 22:21:06.046 Using Diffie-Hellman with standard group "group1"
. 2006-01-02 22:21:06.046 Doing Diffie-Hellman key exchange
. 2006-01-02 22:21:08.234 Host key fingerprint is:
. 2006-01-02 22:21:08.234 ssh-rsa 1040 8d:06:8e:00:64:b5:2a:c5:a5:15:ab:9d:c0:b1:1b:49
. 2006-01-02 22:21:08.234 Initialised AES-128 client->server encryption
. 2006-01-02 22:21:08.234 Initialised HMAC-SHA1 client->server MAC algorithm
. 2006-01-02 22:21:08.234 Initialised AES-128 server->client encryption
. 2006-01-02 22:21:08.234 Initialised HMAC-SHA1 server->client MAC algorithm
! 2006-01-02 22:21:08.234 Utilisation du nom d'utilisateur "root".
. 2006-01-02 22:21:08.250 Session password prompt (root@10.0.0.1's password: )
. 2006-01-02 22:21:08.250 Using stored password.
. 2006-01-02 22:21:08.250 Sent password
. 2006-01-02 22:21:08.281 Access granted
. 2006-01-02 22:21:08.281 Opened channel for session
. 2006-01-02 22:21:08.343 Started a shell/command
. 2006-01-02 22:21:08.343 --------------------------------------------------------------------------
. 2006-01-02 22:21:08.343 Using SCP protocol.
. 2006-01-02 22:21:08.359 Doing startup conversation with host.
. 2006-01-02 22:21:08.359 Skipping host startup message (if any).
> 2006-01-02 22:21:08.359 echo "WinSCP: this is end-of-file:0"
< 2006-01-02 22:21:08.453 WinSCP: this is end-of-file:0
. 2006-01-02 22:21:08.453 Detecting variable containing return code of last command.
. 2006-01-02 22:21:08.453 Trying "$status".
> 2006-01-02 22:21:08.453 echo "$status" ; echo "WinSCP: this is end-of-file:0"
< 2006-01-02 22:21:08.546 WinSCP: this is end-of-file:0
. 2006-01-02 22:21:08.546 Trying "$?".
> 2006-01-02 22:21:08.546 echo "$?" ; echo "WinSCP: this is end-of-file:0"
< 2006-01-02 22:21:08.703 0
< 2006-01-02 22:21:08.703 WinSCP: this is end-of-file:0
. 2006-01-02 22:21:08.703 Return code variable "$?" selected.
. 2006-01-02 22:21:08.703 Clearing all aliases.
> 2006-01-02 22:21:08.703 unalias "echo" ; echo "WinSCP: this is end-of-file:$?"
! 2006-01-02 22:21:08.703 unalias: echo not found
< 2006-01-02 22:21:08.750 WinSCP: this is end-of-file:1
> 2006-01-02 22:21:08.750 unalias "pwd" ; echo "WinSCP: this is end-of-file:$?"
! 2006-01-02 22:21:08.796 unalias: pwd not found
< 2006-01-02 22:21:08.828 WinSCP: this is end-of-file:1
> 2006-01-02 22:21:08.828 unalias "cd" ; echo "WinSCP: this is end-of-file:$?"
! 2006-01-02 22:21:08.890 unalias: cd not found
< 2006-01-02 22:21:08.937 WinSCP: this is end-of-file:1
> 2006-01-02 22:21:08.937 unalias "ls" ; echo "WinSCP: this is end-of-file:$?"
! 2006-01-02 22:21:09.000 unalias: ls not found
< 2006-01-02 22:21:09.031 WinSCP: this is end-of-file:1
> 2006-01-02 22:21:09.031 unalias "groups" ; echo "WinSCP: this is end-of-file:$?"
! 2006-01-02 22:21:09.078 unalias: groups not found
< 2006-01-02 22:21:09.109 WinSCP: this is end-of-file:1
> 2006-01-02 22:21:09.109 unalias "scp" ; echo "WinSCP: this is end-of-file:$?"
! 2006-01-02 22:21:09.187 unalias: scp not found
< 2006-01-02 22:21:09.234 WinSCP: this is end-of-file:1
> 2006-01-02 22:21:09.234 unalias "rm" ; echo "WinSCP: this is end-of-file:$?"
! 2006-01-02 22:21:09.281 unalias: rm not found
< 2006-01-02 22:21:09.312 WinSCP: this is end-of-file:1
> 2006-01-02 22:21:09.312 unalias "mv" ; echo "WinSCP: this is end-of-file:$?"
< 2006-01-02 22:21:09.468 WinSCP: this is end-of-file:1
> 2006-01-02 22:21:09.468 unalias "mkdir" ; echo "WinSCP: this is end-of-file:$?"
! 2006-01-02 22:21:09.468 unalias: mv not found
! 2006-01-02 22:21:09.468 unalias: mkdir not found
< 2006-01-02 22:21:09.515 WinSCP: this is end-of-file:1
> 2006-01-02 22:21:09.515 unalias "chmod" ; echo "WinSCP: this is end-of-file:$?"
< 2006-01-02 22:21:09.671 WinSCP: this is end-of-file:1
> 2006-01-02 22:21:09.671 unalias "chgrp" ; echo "WinSCP: this is end-of-file:$?"
! 2006-01-02 22:21:09.671 unalias: chmod not found
! 2006-01-02 22:21:09.687 unalias: chgrp not found
< 2006-01-02 22:21:09.718 WinSCP: this is end-of-file:1
> 2006-01-02 22:21:09.718 unalias "chown" ; echo "WinSCP: this is end-of-file:$?"
< 2006-01-02 22:21:09.843 WinSCP: this is end-of-file:1
> 2006-01-02 22:21:09.843 unalias "unset" ; echo "WinSCP: this is end-of-file:$?"
! 2006-01-02 22:21:09.843 unalias: chown not found
< 2006-01-02 22:21:09.937 WinSCP: this is end-of-file:1
> 2006-01-02 22:21:09.937 unalias "unalias" ; echo "WinSCP: this is end-of-file:$?"
! 2006-01-02 22:21:09.937 unalias: unset not found
< 2006-01-02 22:21:10.000 WinSCP: this is end-of-file:1
> 2006-01-02 22:21:10.000 unalias "alias" ; echo "WinSCP: this is end-of-file:$?"
! 2006-01-02 22:21:10.000 unalias: unalias not found
< 2006-01-02 22:21:10.062 WinSCP: this is end-of-file:1
> 2006-01-02 22:21:10.062 unalias "ln" ; echo "WinSCP: this is end-of-file:$?"
! 2006-01-02 22:21:10.062 unalias: alias not found
< 2006-01-02 22:21:10.125 WinSCP: this is end-of-file:1
> 2006-01-02 22:21:10.125 unalias "cp" ; echo "WinSCP: this is end-of-file:$?"
! 2006-01-02 22:21:10.125 unalias: ln not found
< 2006-01-02 22:21:10.171 WinSCP: this is end-of-file:1
. 2006-01-02 22:21:10.171 Clearing national user variables.
> 2006-01-02 22:21:10.171 unset "LANG" ; echo "WinSCP: this is end-of-file:$?"
! 2006-01-02 22:21:10.171 unalias: cp not found
< 2006-01-02 22:21:10.218 WinSCP: this is end-of-file:0
> 2006-01-02 22:21:10.218 unset "LANGUAGE" ; echo "WinSCP: this is end-of-file:$?"
< 2006-01-02 22:21:10.265 WinSCP: this is end-of-file:0
> 2006-01-02 22:21:10.265 unset "LC_CTYPE" ; echo "WinSCP: this is end-of-file:$?"
< 2006-01-02 22:21:10.312 WinSCP: this is end-of-file:0
> 2006-01-02 22:21:10.312 unset "LC_COLLATE" ; echo "WinSCP: this is end-of-file:$?"
< 2006-01-02 22:21:10.390 WinSCP: this is end-of-file:0
> 2006-01-02 22:21:10.390 unset "LC_MONETARY" ; echo "WinSCP: this is end-of-file:$?"
< 2006-01-02 22:21:10.437 WinSCP: this is end-of-file:0
> 2006-01-02 22:21:10.437 unset "LC_NUMERIC" ; echo "WinSCP: this is end-of-file:$?"
< 2006-01-02 22:21:10.484 WinSCP: this is end-of-file:0
> 2006-01-02 22:21:10.484 unset "LC_TIME" ; echo "WinSCP: this is end-of-file:$?"
< 2006-01-02 22:21:10.531 WinSCP: this is end-of-file:0
> 2006-01-02 22:21:10.531 unset "LC_MESSAGES" ; echo "WinSCP: this is end-of-file:$?"
< 2006-01-02 22:21:10.578 WinSCP: this is end-of-file:0
> 2006-01-02 22:21:10.578 unset "LC_ALL" ; echo "WinSCP: this is end-of-file:$?"
< 2006-01-02 22:21:10.687 WinSCP: this is end-of-file:0
> 2006-01-02 22:21:10.687 unset "HUMAN_BLOCKS" ; echo "WinSCP: this is end-of-file:$?"
< 2006-01-02 22:21:10.718 WinSCP: this is end-of-file:0
. 2006-01-02 22:21:10.718 Looking up groups and users.
> 2006-01-02 22:21:10.718 groups ; echo "WinSCP: this is end-of-file:$?"
! 2006-01-02 22:21:10.812 -sh: groups: not found
< 2006-01-02 22:21:10.828 WinSCP: this is end-of-file:127
* 2006-01-02 22:21:10.828 (ECommand) Erreur lors de la recherche des groupes d'utilisateurs.
* 2006-01-02 22:21:10.828 La commande 'groups'
* 2006-01-02 22:21:10.828 a chou avec pour code de retour 127 et pour message
* 2006-01-02 22:21:10.828 -sh: groups: not found.
. 2006-01-02 22:21:12.359 Getting current directory name.
> 2006-01-02 22:21:12.359 pwd ; echo "WinSCP: this is end-of-file:$?"
< 2006-01-02 22:21:12.375 /tmp/root
< 2006-01-02 22:21:12.421 WinSCP: this is end-of-file:0
. 2006-01-02 22:21:12.421 Listing current directory.
> 2006-01-02 22:21:12.421 ls -la --full-time ; echo "WinSCP: this is end-of-file:$?"
! 2006-01-02 22:21:12.515 ls: unrecognized option `--full-time'
! 2006-01-02 22:21:12.531 BusyBox v1.00 (2005.04.21-17:30+0000) multi-call binary
! 2006-01-02 22:21:12.531 Usage: ls [-1AacCdeFilnpLRrSsTtuvwxXhk] [filenames...]
! 2006-01-02 22:21:12.531 List directory contents
! 2006-01-02 22:21:12.531 Options:
! 2006-01-02 22:21:12.531 -1 list files in a single column
! 2006-01-02 22:21:12.531 -A do not list implied . and ..
! 2006-01-02 22:21:12.531 -a do not hide entries starting with .
! 2006-01-02 22:21:12.531 -C list entries by columns
! 2006-01-02 22:21:12.531 -c with -l: show ctime
! 2006-01-02 22:21:12.531 -d list directory entries instead of contents
! 2006-01-02 22:21:12.531 -e list both full date and full time
! 2006-01-02 22:21:12.531 -F append indicator (one of */=@|) to entries
! 2006-01-02 22:21:12.531 -i list the i-node for each file
! 2006-01-02 22:21:12.531 -l use a long listing format
! 2006-01-02 22:21:12.531 -n list numeric UIDs and GIDs instead of names
! 2006-01-02 22:21:12.531 -p append indicator (one of /=@|) to entries
! 2006-01-02 22:21:12.531 -L list entries pointed to by symbolic links
! 2006-01-02 22:21:12.531 -R list subdirectories recursively
! 2006-01-02 22:21:12.531 -r sort the listing in reverse order
! 2006-01-02 22:21:12.531 -S sort the listing by file size
! 2006-01-02 22:21:12.531 -s list the size of each file, in blocks
! 2006-01-02 22:21:12.531 -T NUM assume Tabstop every NUM columns
! 2006-01-02 22:21:12.531 -t with -l: show modification time
! 2006-01-02 22:21:12.531 -u with -l: show access time
! 2006-01-02 22:21:12.531 -v sort the listing by version
! 2006-01-02 22:21:12.531 -w NUM assume the terminal is NUM columns wide
! 2006-01-02 22:21:12.531 -x list entries by lines instead of by columns
! 2006-01-02 22:21:12.531 -X sort the listing by extension
! 2006-01-02 22:21:12.531 -h print sizes in human readable format (e.g., 1K 243M 2G )
< 2006-01-02 22:21:12.578 WinSCP: this is end-of-file:1
* 2006-01-02 22:21:12.578 (ETerminal) La commande 'ls -la --full-time'
* 2006-01-02 22:21:12.578 a chou avec pour code de retour 1 et pour message
* 2006-01-02 22:21:12.578 ls: unrecognized option `--full-time'
* 2006-01-02 22:21:12.578 BusyBox v1.00 (2005.04.21-17:30+0000) multi-call binary
* 2006-01-02 22:21:12.578 Usage: ls [-1AacCdeFilnpLRrSsTtuvwxXhk] [filenames...]
* 2006-01-02 22:21:12.578 List directory contents
* 2006-01-02 22:21:12.578 Options:
* 2006-01-02 22:21:12.578 -1 list files in a single column
* 2006-01-02 22:21:12.578 -A do not list implied . and ..
* 2006-01-02 22:21:12.578 -a do not hide entries starting with .
* 2006-01-02 22:21:12.578 -C list entries by columns
* 2006-01-02 22:21:12.578 -c with -l: show ctime
* 2006-01-02 22:21:12.578 -d list directory entries instead of contents
* 2006-01-02 22:21:12.578 -e list both full date and full time
* 2006-01-02 22:21:12.578 -F append indicator (one of */=@|) to entries
* 2006-01-02 22:21:12.578 -i list the i-node for each file
* 2006-01-02 22:21:12.578 -l use a long listing format
* 2006-01-02 22:21:12.578 -n list numeric UIDs and GIDs instead of names
* 2006-01-02 22:21:12.578 -p append indicator (one of /=@|) to entries
* 2006-01-02 22:21:12.578 -L list entries pointed to by symbolic links
* 2006-01-02 22:21:12.578 -R list subdirectories recursively
* 2006-01-02 22:21:12.578 -r sort the listing in reverse order
* 2006-01-02 22:21:12.578 -S sort the listing by file size
* 2006-01-02 22:21:12.578 -s list the size of each file, in blocks
* 2006-01-02 22:21:12.578 -T NUM assume Tabstop every NUM columns
* 2006-01-02 22:21:12.578 -t with -l: show modification time
* 2006-01-02 22:21:12.578 -u with -l: show access time
* 2006-01-02 22:21:12.578 -v sort the listing by version
* 2006-01-02 22:21:12.578 -w NUM assume the terminal is NUM columns wide
* 2006-01-02 22:21:12.578 -x list entries by lines instead of by columns
* 2006-01-02 22:21:12.578 -X sort the listing by extension
* 2006-01-02 22:21:12.578 -h print sizes in human readable format (e.g., 1K 243M 2G ).
. 2006-01-02 22:21:12.578 Directory listing with --full-time failed, try again regular listing.
. 2006-01-02 22:21:12.578 Listing current directory.
> 2006-01-02 22:21:12.578 ls -la ; echo "WinSCP: this is end-of-file:$?"
< 2006-01-02 22:21:12.640 drwx------ 1 root root 0 Jan 1 1970 .
< 2006-01-02 22:21:12.640 drwxrwxrwx 1 root root 0 Jan 1 2000 ..
< 2006-01-02 22:21:12.640 drwx------ 1 root root 0 Jan 1 1970 .ssh
< 2006-01-02 22:21:12.671 WinSCP: this is end-of-file:0
. 2006-01-02 22:21:12.671 Startup conversation with host finished.
Where is my bad setup?
Emmanuel
Please read documentation.
