Topic "Double click on unknown file"
Wurm
Hi, I haven't found anything about this. Can someone give me a hint?
- I have changed standard operation on double click to "Edit".
- the editor is proper configured: If I use "Ctrl-E" on a file everthing works fine, the file is transferd and opened with the editor.
- if I double click on any file I get an error code 4. It seems that WinSCP wants to open the remote file "as a directory" instead of transfering it to my local machine
I am using the latetest version. Any ideas? Thanks!
Please read documentation
Wurm
I have read the documentation before, now I have read the part again you linked to. Thank you, but I don't see a solution for my problem. Can you give me an exact hint? Which option do I have to use?
Quote:
The option is effectivelly ignored when resolving of symbolic links is disabled for current session, in which case double-clicking file is always interpreted as attempt to open it, just in case it is unresolved symbolic link.
I've done that, it doesn't work. I get an error no matter what I do.
dpknc84
^ My post, just to clarify.
I have symbolic links enabled and edit on double click set for my session. It doesn't work. It throws error code 4 no matter what I do. Bug maybe?
Frustrated.
What version of WinSCP are you using? SCP or SFTP protocol? Can you post a full error message?
dpknc84
Quote:
General failure (server should provide error description).
Error code: 4
Error message from server: None
Request code: 11
When trying to double click on a .cfm file using version 3.8.0 (build 312) of WinSCP. I'm using the SFTP protocol w/ SCP fallback.
I do not think that's a full error message. I think there is probably main error message and you posted is just a detail (debug) information, associated with it.
Wurm
I don't know what you mean with 'a full error message' but this what you get. Can't you reproduce the error?
Typically, what was posted is message revealed if you press "more" button. There should be "main error", visible even without pressing "more" button.
Wurm
'Fehler beim Anzeigen des Verzeichnisses "/export/home/myuser/file.txt"'
I have the german version. The english message should be something like
'Error when displaying directory "/export/home/myuser/file.txt"'
I'm 99% sure that this is caused by you not having resolved symlinks. See the link in my first post. However, I've realized that there is not only possibility that you have disabled the resolving, but also that the server does not support it. This is the case for SFTP protocol version 2 and lower. This is very uncommon, but it can be the case. Is it?
Wurm
It is. Many thanks!
sftp> version
I have tried another server and it works. I guess there is no solution to get this feature work with SFTP protocol version 2?
Of course, I may add an option for this, but as SFTP version 2 is hardly used, I do not give it high priority.
