Error Listing Directories starting with numbers
Tibi
Hey there,
I have combined two scripts form the documentation from here, the problem ist. I am getting a Error everytime I want to Fetch Files/Folders starting with numbers.
Exact Error: "Exception calling Check with 0 arguments: Error listing directory ... Could not retrieve directory listing" and this only happens, if the folders, I want to download starts with numbers.
Btw it's a FTPES
try
   $sessionUrl = "ftp://dadsa:dasd@Sdad1.syx:123/"
   $remotePath = "/test/"
   $localPath = "E:\test"
   $lastTimestamp = $Null
   $timestampFile = "E:\timestamp.txt"
    # WINSCP DLL
    # FTP Session
   $sessionOptions.FtpMode = [WinSCP.FtpMode]::passive
    try
   if (Test-Path $timestampFile)
      $lastTimestamp = [DateTime]::ParseExact((Get-Content $timestampFile), 'O', $Null)
   else
    if ($lastTimestamp -ne $Null)
        Write-Host "Downloading files modified after $lastTimestamp..."
        $transferOptions.FileMask = ("*>" + $lastTimestamp.ToString("yyyy-MM-dd HH:mm:ss"))
    else
        Write-Host "Downloading all files..."
    $transferResult = $session.GetFiles($remotePath, $localPath, $False, $transferOptions)
    $transferResult.Check()
    # Find the latest downloaded file
    $latestTransfer =
        $transferResult.Transfers |
        Sort-Object -Property @{ Expression = { (Get-Item $_.Destination).LastWriteTime } } `
                    -Descending |
        Select-Object -First 1
    if ($latestTransfer -eq $Null)
        Write-Host "No files found."
    else
        $lastTimestamp = (Get-Item $latestTransfer.Destination).LastWriteTime
        Write-Host (
            "Downloaded $($transferResult.Transfers.Count) files, " +
            "latest being $($latestTransfer.FileName) with timestamp $lastTimestamp.")
    Write-Host "Waiting..."
    Start-Sleep -Seconds 5
   Set-Content -Path $timestampFile -Value $lastTimestamp.ToString("O")
    finally
        # Disconnect, clean up
        $session.Dispose()
    $result = 0
catch
    $result = 1
if ($pause)
exit $result
Re: Error Listing Directories starting with numbers
Tibi
The log file
I added the log file as attachment and trimmed, as far as I could.
Btw: The files are definitely available on the server
  • log.txt (8.58 KB, Private file)
Are you sure it's about the numbers? Can you download other any other subfolders from the test folder? Isn't it that you cannot download any subfolders at all? It's possible that your server cannot handle a command like CWD /XXXXX/10.this.is.a.test-hello-abc (i.e. changing to a folder two levels deep in one step).
Tibi
Problem
Hmm, I tested other directories as well.. I guess, thats not the numbers, I tested a other remote folder which contains folders that also starts with numbers and they're just working fine. Somehow a few doesn't work. Downloading folders manually works fine.
CWD is supported
Re: Problem
So please post a log file for both these scenarios as well (other folders what work fine and the manual download).
Tibi
I attached a logfile for a working directory, that I downloaded with the script. Which contains 2 folders, that where downloaded.
  • log.log (67.42 KB, Private file)
