VBA & GSSAPI
Berube
VBA & GSSAPI
Are there any known issues with SessionOptions.AddRawSettings in a 64-bit VBA environment? My code is working with one exception: even though I have
SessionOptions.AddRawSettings "AuthGSSAPI", "0"
my session is logging in using GSSAPI instea of the usedID and password every time. (The server accepts but does not require GSSAPI logins; if I turn it off in the WinSCP client, it connects correctly.)
Re: VBA & GSSAPI
Can you please share your full code? And a full session log file showing the problem (using the latest version of WinSCP).
Berube
VBA & GSSAPI
I am attaching 3 files:
- UploadSFTP is my code, patterned after the example code from your site
- WinSCP.log is the log of the comnnection session
- WinSCP2.log is a second log for another issue I encountered yesterday. If I replace Session.Open with Session.ScanFingerprint, the connection fails. This log reflects that action. (Note that nothing else was changed in the code; the userID was provided, even though it doesn't appear in the log.)
(After editing and posting these logs, I noticed I was using version 5.17.2 instead of 5.17.3. I regenerated both logs with 5.17.3 and the files were identical except for the version numbers.)
Re: VBA & GSSAPI
Thanks for the logs.
