Exiting a batch file
gs1111
I have a batch file which downloads data from a directory.
( "get -delete _MainDir/SubDir/*  D:\DestinationDir\"  )
The problem is that when there is nothing to download, the script stops and does not exit the CMD.exe dialogue.
This means that when checking every 5 minutes for data, I compound the number of cmd.exe dialogues on the screen.
I need a feature that when the system fails to find a file in the directory, the script is abandoned and I don't end up with a massive build up of cmd.exe screens
Re: Exiting a batch file
That's not how WinSCP behaves on its own. It must be related to how you use/run WinSCP. We need a full example.
