Topic "Timeout after 'Using username xxxxxxx'"
bsturner
I have about 40 clients that connect to an openssh server on a FreeBSD 4 box. I only have one client that can't connect to the box. They are using WinSCP 3.7.6. I've upped the timeout to as much as 120 seconds, but get the same result. We've also tried to connect with putty, but get the same result. Here is an attempted connection log:
. 2006-03-03 15:14:54.955 --------------------------------------------------------------------------
. 2006-03-03 15:14:54.955 WinSCP Version 3.7.6 (Build 306) (OS 5.1.2600 Service Pack 2)
. 2006-03-03 15:14:54.955 Login time: Friday, March 03, 2006 3:14:54 PM
. 2006-03-03 15:14:54.955 Session name: bturner@XXX.XXX.XX.XXX
. 2006-03-03 15:14:54.955 Host name: XXX.XXX.XX.XXX (Port: 22)
. 2006-03-03 15:14:54.955 User name: bturner (Password: No, Key file: No)
. 2006-03-03 15:14:54.955 Transfer Protocol: SFTP (SCP)
. 2006-03-03 15:14:54.970 SSH protocol version: 2; Compression: No
. 2006-03-03 15:14:54.970 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2006-03-03 15:14:54.970 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2006-03-03 15:14:54.970 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2006-03-03 15:14:54.970 SSH Bugs: -,-,-,-,-,-,-,-
. 2006-03-03 15:14:54.970 SFTP Bugs: -,-,-
. 2006-03-03 15:14:54.970 Proxy: none
. 2006-03-03 15:14:54.970 Return code variable: Autodetect; Lookup user groups: Yes
. 2006-03-03 15:14:54.970 Shell: default, EOL: 0
. 2006-03-03 15:14:54.970 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2006-03-03 15:14:54.970 Cache directory changes: Yes, Permanent: Yes
. 2006-03-03 15:14:54.970 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2006-03-03 15:14:54.970 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2006-03-03 15:14:54.970 --------------------------------------------------------------------------
. 2006-03-03 15:14:55.002 Looking up host "XXX.XXX.XX.XXX"
. 2006-03-03 15:14:55.002 Connecting to XXX.XXX.XX.XXX port 22
. 2006-03-03 15:14:55.236 Waiting for the server to continue with the initialisation
. 2006-03-03 15:14:55.236 Looking for incoming data
. 2006-03-03 15:14:55.252 Select result is 1
. 2006-03-03 15:14:55.252 Server version: SSH-2.0-OpenSSH_3.5p1 FreeBSD-20030924
. 2006-03-03 15:14:55.252 We claim version: SSH-2.0-WinSCP_release_3.7.6
. 2006-03-03 15:14:55.252 Using SSH protocol version 2
. 2006-03-03 15:14:55.252 Waiting for the server to continue with the initialisation
. 2006-03-03 15:14:55.252 Looking for incoming data
. 2006-03-03 15:14:55.502 Select result is 1
. 2006-03-03 15:14:55.517 Doing Diffie-Hellman group exchange
. 2006-03-03 15:14:55.517 Waiting for the server to continue with the initialisation
. 2006-03-03 15:14:55.517 Looking for incoming data
. 2006-03-03 15:14:56.252 Select result is 1
. 2006-03-03 15:14:56.267 Doing Diffie-Hellman key exchange
. 2006-03-03 15:14:56.908 Waiting for the server to continue with the initialisation
. 2006-03-03 15:14:56.908 Looking for incoming data
. 2006-03-03 15:14:57.611 Select result is 1
. 2006-03-03 15:14:58.580 Host key fingerprint is:
. 2006-03-03 15:14:58.580 ssh-dss 1024 e0:f2:e4:2f:85:46:cf:b6:55:62:d6:ad:18:80:8a:13
. 2006-03-03 15:14:58.580 Initialised AES-256 client->server encryption
. 2006-03-03 15:14:58.580 Initialised HMAC-SHA1 client->server MAC algorithm
. 2006-03-03 15:14:58.580 Initialised AES-256 server->client encryption
. 2006-03-03 15:14:58.580 Initialised HMAC-SHA1 server->client MAC algorithm
. 2006-03-03 15:14:58.580 Waiting for the server to continue with the initialisation
. 2006-03-03 15:14:58.580 Looking for incoming data
. 2006-03-03 15:14:59.002 Select result is 1
! 2006-03-03 15:14:59.002 Using username "bturner".
. 2006-03-03 15:14:59.002 Waiting for the server to continue with the initialisation
. 2006-03-03 15:14:59.002 Looking for incoming data
. 2006-03-03 15:15:14.002 Select result is 0
. 2006-03-03 15:15:14.002 Waiting for data timed out, asking user what to do.
. 2006-03-03 15:15:14.017 Asking user:
. 2006-03-03 15:15:14.017 Host has not answered for 15 seconds.
. 2006-03-03 15:15:14.017 Wait for another 15 seconds? Pressing 'Abort' button will close session. ()
Has anyone seen anything similar? It's isolated to this one client. The rest of my users have no problems at all, and are using various versions of winscp and putty.
Thanks.
