Scripting - Delete all files and directories
Confuzed
I want my script to delete the entire contents of the remote working directory, files AND subdirectories.
It errors on the "rm *" if there is a directory in the remote working directory, and it appears that rmdir will not accept a wildcard.
I have tried both sftp and scp with no luck. Please advise.
Also, what happens if the remote working directory specified by the 'cd' command in my script is missing... does it default to something,or fail the script. I would hate to run the 'rm *' in the wrong directory!
Joe
Re: Scripting - Delete all files and directories
That's not possible currently. But you can remote the whole directory and create new empty one.
That depends on configuration. See "help option" for "batch" option.
I'm not sure I follow you... could you explain a little clearer?
I did a "help option" and the only thing I can see that MAY help is the abort option. Would the inablity to open the remote directory I specify in the script result in an error that would cause the abort?
By the way, great product... I absolutely love people inspired enough to produce a valuable product for free... I love them even more when they offer such responsive support!
Just tested that and it does... now I just need to find a way to recursively delete all files and directories under the remote working directory.
[quote="Anonymous"]
Nevermind... I figured it out... just did a
call rm -f -r -v *
and the files are gone!
Thanks again for a great product.
I'll try and convince my boss to donate!
Joe
