How to ignore permissions
Dan Curious
NY
I'm getting the standard message, but can't figure out how to ignore permissions.
Upload of file 'XXXXX' was successful, but error occurred while setting the permissions and/or timestamp.
If the problem persists, turn off setting permissions or preserving timestamp. Alternatively you can turn on 'Ignore permission errors' option. ("The server does not support the operation.")
This is the VBScript code for setting the transfer options. The returned object is then used in PutFiles(). I don't remember why we are using RawSettings; I think it's because a straight assignment like
TransferOptions_obj.Permissions = False
doesn't work. That was some time back.
Function wscp_GetTransferOptions
    Dim TransferOptions_obj
    Set TransferOptions_obj = WScript.CreateObject( "WinSCP.TransferOptions" )
    ' TransferOptions_obj.OverwriteMode = OverwriteMode_Overwrite
    ' TransferOptions_obj.PreserveTimestamp = False
    ' TransferOptions_obj.Permissions = False
    ' TransferOptions_obj.AddRawSettings "PreserveTimeDirs", 1
    TransferOptions_obj.AddRawSettings "IgnorePermErrors", 1
    TransferOptions_obj.AddRawSettings "PreserveTimestamp", 0
    If Err.number  <> 0 Then
        Transfer_Succeeded_b = False
        ErrorNumber = Err.number
        ErrorDescription = Err.Description
        ErrorSource = Err.Source
        Err.Clear
        Call udfs_LogError( "Problem with Transfer options", ErrorNumber, ErrorDescription, ErrorSource )
    End If
    Set wscp_GetTransferOptions = TransferOptions_obj
End Function
Re: How to ignore permissions
Also show us how are you using wscp_GetTransferOptions with PutFiles.
Also check https://winscp.net/eng/docs/faq_library_parameters
Dan Curious
NY
We downloaded the latest copy of the COM component, and Unregistered the existing component.
When we try to register again, we get an error with both the 32-bit and the 64-bit version:
c:\windows\microsoft.NET\Framework64\v4.0.30319\RegAsm.exe WinSCPnet.dll /codebase /tlb
Microsoft .NET Framework Assembly Registration Utility version 4.8.3752.0
for Microsoft .NET Framework version 4.8.3752.0
Copyright (C) Microsoft Corporation.  All rights reserved.
Types registered successfully
RegAsm : error RA0000 : An error occurred while saving the exported type library: Access is denied. (Exception from HRESULT: 0x80070005 (E_ACCESSDENIED))
We're in Admin mode, at the command prompt. Should we reboot?
Yep, we generate the .LOG files daily.
What the most recent version of the COM component of WinSCP? We have
WinSCPNet.dll 1/26/2021, 8:07 am
It's possible that the type library file is locked, so yes, reboot can help.
1/26/2021 is definitely not the latest version of WinSCP. The latest version, 5.19.2, was released on 2021-07-27.
Dan Curious
NY
We haven't resolved this, yet. Because of the
"...was successful, but error occurred..." error,
we keep getting false positive when determining whether a transmission took place.
The log says the command line is interpreted as
     "put  -nopermissions -preservetime -transfer="binary" -rawtransfersettings[3] IgnorePermErrors="1" PreserveTimestamp="0" Permissions="0""
What are we doing wrong?
This is the transfer code we're using:
TransferOptions_obj.TransferMode = 0
TransferOptions_obj.AddRawSettings "IgnorePermErrors", "1"
TransferOptions_obj.AddRawSettings "PreserveTimestamp", "0"
TransferOptions_obj.AddRawSettings "Permissions", "0"
It seems that your server does not support preserving timestamps:
< 2021-08-16 06:30:43.390 Type: SSH_FXP_STATUS, Size: 40, Number: 1033
< 2021-08-16 06:30:43.391 Status code: 8, Message: 1033, Server: Operation unsupported, Language: en
* 2021-08-16 06:30:43.393 (ETerminal) The server does not support the operation.
So you need to uncomment the:
Dan Curious
NY
Looks good. There was no error flagged from this script:
transferResult.Check
Result_x = transferResult.IsSuccess()
   Err.Clear
   Call udfs_LogError( "Problem Transferring " & File_From_s & " to " & File_To_s, ErrorNumber, ErrorDescription, ErrorSource )
   Call udfs_SendErrorMessage( "Problem Transferring " & File_From_s & " to " & File_To_s, ErrorNumber, ErrorDescription, ErrorSource )
End If
But there was also no 'successful' string in the WinSCP log file.
In the WinSCP log (attached), does the Zero exit code in
. 2021-08-24 07:03:24.865 Script: Exit code: 0
mean that the transmission was successful?
You can tell that the transfer was successful by inspecting the TransferOperationResult.IsSuccess – what you are already doing. The log file shall not be used for any decisions.
