Oracle Cloud Object Store
Re: Oracle Cloud Object Store
What kind of support does it need? If Oracle supports S3, you should be able to just specify the Oracle endpoint on WinSCP login dialog.
I did some tests. While I was able to connect and see the buckets, I could not see files nor I was able to transfer any. But I had similar problems even with other S3 clients. It does not look like Oracle Cloud has good compatibility with S3. Were you able to use any S3 client against Oracle Cloud successfully?
Do you want to use WinSCP GUI or scripting? If GUI, were you able to use any GUI S3 client against the Oracle Cloud? GUIs have different requirements than command-line clients.
