WinSCP creates folder when mainframe library non-existent
user10180
I am using WinSCP to ftp files to a Mainframe server, and observed a problem.
When WinSCP copies to an existing library on mainframe, the copying works fine. But when library does not exist on mainframe already, WinSCP copies files as individual files, not under a library.
Example:
USER.A1.A11 exists already and WinSCP has to copy a file (FILE1), it will copy the file correctly under library USER.A1.A11.
But when USER.A2.A22 library does not exist on Mainframe, and WinSCP tries to copy a file (FILE2), it copies it as an individual file like USER.A2.A22.FILE2.
Is there a way this behavior can be fixed?
I am using following options:
WinSCP /ini=nul /console /command
"open ftp://user:password@ftpserver:21 -passive=on -explicittls"
"option confirm off" "call SITE site.."
"CD 'USER1.A2.A22'"
"put \\location\\* -transfer=ASCII"
"close" "exit"
user10180
Re: WinSCP creates folder when mainframe library non-existent
Please see the logs attached. The only notable difference is on Line 10, with an extra dot when library does not exist already on Mainframe server.
  • log when library does not exist.txt (610 Bytes, Private file)
  • log when library exists.txt (609 Bytes, Private file)
Session log please. Not console output.
