Cannot create an instance of the following .NET Framework object: assembly WinSCPnet
manigandanece@gmail.com
cehnnai
We got an error while pulling data from the dynamics application
Microsoft Dynamics 365 Business Central
Cannot create an instance of the following .NET Framework object: assembly WinSCPnet, Version=1.4.0.7781, Culture=neutral, PublicKeyToken=2271ec4a3c56d0bf, type WinSCP.SessionOptions.
Re: Cannot create an instance of the following .NET Framework object: assembly WinSCPnet
Sorry, I do not know "Microsoft Dynamics 365 Business Central". And the error message does not contain any useful information. Nor did you detailed how are you using/referencing WinSCP .NET assembly.
hasnainali
I'm facing same issue.
Did you get the solution?
