A Way to Disable Folder Caching
Hi all
If I connect to a remote server, and navigate to some folder (e.g.
and then, I navigate to another folder (e.g.
then I navigate again to
then I will not see the new content of that folder.
I tried searching the Settings for anything that could disbale Folder Caching,
but couldn't find.
I only found an option for Auto-Refresh, with the ability to choose how many seconds between each Refresh,
but that's not what I am looking for..
If I am on a certain folder, I would not like to to refresh all the time..
But If I leave a folder, and then go back to it again,
I would certainly want to have it reloaded from the server.
Is there an option to do that (which I maybe did not find)?
Or If not, can I please recommend adding that as a Setting in the same Setting screen as the Auto-Refresh one?
Thank you very much
/Folder1), and view its content,
/Folder2), and meanwhile /Folder1 was added with a new file, or a file was deleted there,
/Folder1,
but couldn't find.
Thank you very much
