WinSCP-release-6.1.1: TransferOptions:PreserveTimestamp = TRUE ignored?
BernhardKraml
Austria
I do my first steps with .NET automation.
When uploading files to the FTP-server, I always get the current time as timestamp of the uploaded file.
I upload the files with PutFiles()
Thanks for your help!
-bernhard
The FTP server reports the following features:
> 2023-08-10 17:09:17.744 FEAT
< 2023-08-10 17:09:17.746 211-Extensions supported:
< 2023-08-10 17:09:17.779  SSCN
< 2023-08-10 17:09:17.779  PBSZ
< 2023-08-10 17:09:17.780  PROT
< 2023-08-10 17:09:17.780  CCC
< 2023-08-10 17:09:17.780  CLNT
< 2023-08-10 17:09:17.780  EPSV
< 2023-08-10 17:09:17.780  EPRT
< 2023-08-10 17:09:17.780  MDTM
< 2023-08-10 17:09:17.797  MDTM YYYYMMDDHHMMSS[+-TZ];filename
< 2023-08-10 17:09:17.797  MFMT
< 2023-08-10 17:09:17.797  SIZE
< 2023-08-10 17:09:17.797  REST STREAM
< 2023-08-10 17:09:17.797  MODE Z
< 2023-08-10 17:09:17.797  LIST -Q
< 2023-08-10 17:09:17.797  SITE UTIME
< 2023-08-10 17:09:17.797  SITE MD5
< 2023-08-10 17:09:17.797  XMD5
< 2023-08-10 17:09:17.797  SITE MD5s
< 2023-08-10 17:09:17.797  SITE RANDOMACCESS
< 2023-08-10 17:09:17.797  MLST Type*;Size*;Modify*;Perm*;UNIX.owner*;UNIX.group*;
< 2023-08-10 17:09:17.797  UTF8
< 2023-08-10 17:09:17.797 211 END
Re: WinSCP-release-6.1.1: TransferOptions:PreserveTimestamp = TRUE ignored?
BernhardKraml
Austria
I did an upload to the FTP server (TimeStamp 16:36) and a download shortly after (TimeStamp 16:38).
I had the following transferoptions:
transferOptions:TransferMode = TransferMode:BINARY.
transferOptions:PreserveTimestamp = TRUE.
I found in the log file part with the download
2023-08-16 16:38:55.305 Preserving timestamp [2023-08-16T14:35:57.000Z]
There is nothing like this in the upload.
-bernhard
  • Testftp.log (30.82 KB, Private file)
WinSCP requested timestamp update correctly and the server have ignored that.
> 2023-08-16 16:36:00.530 MFMT 20230810135837 Testftp.txt
< 2023-08-16 16:36:00.536 213 Modify=20230816163557; Testftp.txt
So it does seem to be a server-side problem.
BernhardKraml
Austria
Thank you very much for your help.
I asked the owner of the FTP server and she told me that they disabled the function of saving the TimeStamp so they would know the upload time.
-bernhard
