Scripting synchronization options
I've been trying to make my WinSCP script synchronize with the options I want but there's one thing I can't set. How do I unset the 'Existing Files Only' flag?
Thanks very much.
Jon.
Re: Scripting synchronization options
It is unset by default. If you have turned it on from GUI, turn it off there. You cannot change it from the script.
Ok, thanks. So when the flag is set or unset in the GUI it must change something probably in the registry that WinSCP (when called from the script) looks at. If it is in the registry, what exactly is that?
Thanks very much for your help.
Jon.
Look for attribute SynchronizeParams. It's bitmask, where 0x04 is "existing only". Check also this FAQ to learn how to work with configuration for scripting tasks.
