Select absent directories while "compare"
konstbel
There is a useful function: "Compare directories", but it compares only files. Is it possible to mark also absent subdirectories?
daxue
Re: Select absent directories while "compare"
@konstbel: Good idea! I also hope that WinSCP's 'Compare directories' feature can align identical files and directories. A better dark color mode would make the comparison more easily visible.
Description: Same files and folders aligned.
