After upgrade to latest WinSCP Version mv of remote file to remote folder failing
kevinibt
USA
Version: 6.2.4 RC Build (14759 2024-02-03)
When issuing mv command (or via GUI) of file to another remote folder, getting error
** Host is not communicating for 100 seconds. Wait for another 100 seconds?**. Still waiting...NOTE: If the problem repeats, try turning of 'Optimize Connection Buffer Size'
Again, this worked with WinSCP Version 6.1.2
Re: After upgrade to latest WinSCP Version mv of remote file to remote folder failing
