Username not Working with Session Options when SSH Private Key Auth Utilized
testval123
If I use username/password combination, the script opens with Username as expected, ie. open sftp://user:**@sftp.blah.com:22
However, if I specify SshPrivateKeyPath, it does NOT utilize the username and instead attempts to prompt for it, even if the username is specified in the SessionOptions properties.
Ie. open sftp://blah.com:22
Username:   (Password: NO, Key file: Yes, Passphrase: Yes)
Reading key file"blah.ppk"
Prompt (username, "SSH login name", <no instructions>, "login as:"
Prompting user for credentials.
Prompt cancelled.
User aborted at username prompt
Attempt to close connection due to fatal exception:
**Credentials were not specified**
Why does the username/password work, and not the SSH Key?
Re: Username not Working with Session Options when SSH Private Key Auth Utilized
Please post your code and corresponding session log file (Session.SessionLogPath).
