[WinSCP 6.3]: GUI Download of files simply stops
cmmfl
Florida, USA
Just updated to WinSCP 6.3. Using the GUI tool to download a directory of files, the first couple of files are successfully downloaded and then the tool hangs, with the appearance of "still downloading". I've included a portion of the log, from the point that the last successful download was processed.
. 2024-02-16 12:32:48.456 Download successful
. 2024-02-16 12:32:48.456 Got reply 1 to the command 4
. 2024-02-16 12:32:48.457 Transfer done: '/images/samples/2_small.jpg' => 'C:\xampp\htdocs\xxx\images\samples\2_small.jpg' [4289]
. 2024-02-16 12:32:48.457 File: '/images/samples/3_small.jpg' [2022-03-08T14:32:20.000Z] [5331]
. 2024-02-16 12:32:48.457 Copying "/images/samples/3_small.jpg" to local directory started.
. 2024-02-16 12:32:48.457 Binary transfer mode selected.
. 2024-02-16 12:32:48.458 Starting download of /images/samples/3_small.jpg
> 2024-02-16 12:32:48.458 TYPE I
. 2024-02-16 12:32:48.520 Read 30 bytes
< 2024-02-16 12:32:48.520 200 TYPE is now 8-bit binary
> 2024-02-16 12:32:48.520 PASV
. 2024-02-16 12:32:48.586 Read 52 bytes
< 2024-02-16 12:32:48.586 227 Entering Passive Mode (104,219,13,213,223,114)
> 2024-02-16 12:32:48.586 RETR 3_small.jpg
. 2024-02-16 12:32:48.586 Connecting to 104.219.13.213:57202 ...
. 2024-02-16 12:32:48.586 Connection pending
. 2024-02-16 12:32:48.643 Data connection opened
. 2024-02-16 12:32:48.705 Read 30 bytes
< 2024-02-16 12:32:48.705 150-Accepted data connection
. 2024-02-16 12:32:48.705 Read 28 bytes
< 2024-02-16 12:32:48.705 150 5.2 kbytes to download
. 2024-02-16 12:32:48.705 Data connection opened
. 2024-02-16 12:32:48.705 Trying reuse main TLS session ID
. 2024-02-16 12:32:48.706 Transfer progress: Transferred: 8,416, Left: 0:00:01, CPS: 9,456/s
. 2024-02-16 12:32:48.706 TLS layer changed state from none to connected
. 2024-02-16 12:32:48.769 TLS connect: SSLv3/TLS write client hello
. 2024-02-16 12:32:48.769 TLS connect: SSLv3/TLS read server hello
. 2024-02-16 12:32:48.769 TLS connect: SSLv3/TLS write change cipher spec
. 2024-02-16 12:32:48.770 TLS connect: SSLv3/TLS write client hello
. 2024-02-16 12:32:48.836 TLS connect: SSLv3/TLS write client hello
. 2024-02-16 12:32:48.838 TLS connect: SSLv3/TLS read server hello
. 2024-02-16 12:32:48.838 TLS connect: TLSv1.3 read encrypted extensions
. 2024-02-16 12:32:48.838 TLS connect: SSLv3/TLS read finished
. 2024-02-16 12:32:48.863 TLS connect: SSLv3/TLS write finished
. 2024-02-16 12:32:48.863 Session ID reused
. 2024-02-16 12:32:48.864 Using TLSv1.3, cipher TLSv1.3: TLS_AES_256_GCM_SHA384, 4096 bit RSA, TLS_AES_256_GCM_SHA384         TLSv1.3 Kx=any      Au=any   Enc=AESGCM(256)            Mac=AEAD
. 2024-02-16 12:32:48.864 TLS connection established
. 2024-02-16 12:32:48.924 TLS connect: SSL negotiation finished successfully
. 2024-02-16 12:32:48.924 Session ID changed
. 2024-02-16 12:32:48.924 TLS connect: SSLv3/TLS read server session ticket
. 2024-02-16 12:32:48.924 Read 35 bytes
< 2024-02-16 12:32:48.924 226-File successfully transferred
. 2024-02-16 12:32:48.924 TLS layer changed state from connected to closed
. 2024-02-16 12:32:48.924 Read 60 bytes
< 2024-02-16 12:32:48.924 226 0.000 seconds (measured here), 44.15 Mbytes per second
. 2024-02-16 12:32:48.925 Data connection closed
Re: [WinSCP 6.3]: GUI Download of files simply stops
cmmfl
Unable to replicate
I tried the debug file sent, which did not replicate the issue. Unfortunately, I'm not able to replicate with v6.3 now, either.
