Topic "Version 2.3 does not delete tmp-files"
mpausch
hi,
i installed winscp 2.3 and it does not delete the temp-files (like the versions before).
- drag&drop to copy files
- 3 folders with files (one folder with a sub-folder)
- commander-like style
- win2k sp3 and other patches
thanks and greetings
manfred pausch
In version 2.3, it should work even better than the version before. At least it does for me. Can you check this again?
Please note that temporary folder is not deleted sooner than 2 minutes after transfer completes or when application closes (which ever comes first).
Also folder is not deleted, when something prevents its deletion (like when your have the temporary folder opened).
mpausch
checked it again, and it worked Smile))
another question:
2 minutes after transfer (from remote to local) or
2 minutes after transfer (from temp-folder to destination folder)?
if first statement is true, this could be a problem
with big files Smile
could be, that the temp-folder was opened at my first "test".
is it possible to implement an option for transfer files direct to target-folder (without transfer first to temp-folder). i often handle big files and my temp-folder is on my system-partition (which is the smallest)
hope my english is not tooooooo bad Smile
thanks
mpausch
mpausch wrote:
another question:
The first is true Sad From the time I finish download to temp-folder everything gets out of control of WinSCP. Transfer from temp-folder to destination directory is performed by Windows Explorer, I cannot detect, when it finishes it. Please note that drag&drop is too general, I don't even know, where I've dropped the files. It can even be different file transfer application or compression program (such as WinZip)...
No it is not possible. See explanation above.
See also FAQ.
