Topic "1.5.0 doesn't show all previously saved sessions"
t-rex
A bug or a feature that I noticed with 1.5.0 is that it did not show all my sessions that were saved with the previous version - what I found is that if a session had a name like user@server/path (in the registry) then 1.5.0 would not show it. When I removed the /path section from the name it fixed the problem.
Yes, sessions with slash are ignored.
Where can I find the old sessions in the registry, they are lost?
Under HKEY_USERS\SID\Software\Martin Prikryl\WinSCP 2\Sessions I only have the new ones.
Can I convert the old ones?
Thanx.
Ciao,
Wiesl
The old sessions should be still there. They are not deleted. Just remove the slashes.
