changed root pw
rmac
changed root pw
Hi Prikryl,
I have been using your great software for 3 years now without a problem untill I decided to go and change the root password of my server.. now it throws me this error, I have changed the password in winscp of course.. also I can log into ssh when using Webmin online interface for servers. Please see log file: >>>
Looking up host "xxxxxxxxxxxxx.com"
. Connecting to xxx.xxx.xxx.xx port 22
. Server version: SSH-1.99-OpenSSH_3.5p1
. We claim version: SSH-2.0-WinSCP-release-3.7.1
. Host key fingerprint is:
. ssh-rsa 1024 61:81:e2:8f:da:fe:4a:15:bf:cf:d9:f9:f4:85:f1:5a
. Initialised HMAC-SHA1 client->server MAC algorithm
. Initialised HMAC-SHA1 server->client MAC algorithm
! Using username "root".
. Keyboard-interactive authentication refused
. Session password prompt (root@xxxxxxxxxxxxx.com's password: )
. Using stored password.
. Sent password
. Access granted
* (ESshFatal) Authentication failed.
* Authentication log (see session log for details):
* Using username "root".
* Connection has been unexpectedly closed. Server sent command exit status 0.
how do I get it working again? Please help
regards
rmac
Reply with quote E-mail
Re: changed root pw
I'm not sure if I understand the problem. You have changed root password on the server, changed the password to the same in WinSCP session and it does not connect?
rmac
yes thats correct, :(
the log says "Access granted" then
I feel a bit lame but I have been over and over this .. I must be missing something
rmac
rmac
Here is the error for log,
Jul 18 09:44:09 localhost sshd[22589]: ROOT LOGIN REFUSED FROM xx.xxx.xx.xxx
Jul 18 09:44:09 localhost sshd[22589]: PAM rejected by account configuration[12]: Authentication token is no longer valid; new one required.
Jul 18 09:44:09 localhost sshd[22589]: Failed password for root from xx.xxx.xx.xxx port 53320 ssh2
Jul 18 09:44:09 localhost sshd[22589]: fatal: monitor_read: unsupported request: 24
